Debug I2C simulation
Hi
I want to simulate the I2C, and find this example
// Simulation of I2C Memory (Slave)
MAP 0x010000, 0x01FFFF READ WRITE;
signal void I2CMEMORY (void) {
  unsigned long adr;
  SADR = 0x54;
  adr = 0x010000;
  while (1) {
    wwatch (I2C_OUT);                        // Wait for data from Microcontroller
    while (I2C_OUT == 0x0100) {              // START detected
      if (I2C_OUT > 0xFF) continue;
      if ((I2C_OUT >> 1) != SADR) continue;  // test if Slave is addressed
      I2C_IN = 0xFF00;                       // ACK to Microcontroller
      if (I2C_OUT & 1) {                     // Slave Read
        while (1) {
          I2C_IN = _RBYTE(adr);              // Read Byte from Memory
          adr++;                             // Increment Address
          wwatch (I2C_OUT);                  // Wait for ACK from Microcontroller
          if (I2C_OUT != 0xFF00) break;
      else {                                 // Slave Write
        adr = (I2C_OUT << 8) | 0x010000;     // Set Memory Address High Byte
        adr = I2C_OUT | adr;                 // Set Memory Address Low Byte
        while (1) {
          if (I2C_OUT > 0xFF) break;
          _WBYTE (adr, I2C_OUT);             // Store Byte in Memory
But when I try to open this ini file I get
this error
I2C_OUT
^ *** error 34: undefined identifier
I2C_out and I2C_in are the VTREGs, but here they could not be identified,What can i do now?
