No HID interrupt IN transfers
For a LPC23xx device, I'm adding HID besides MSC. I got everything working fine, except for HID interrupt IN transfers. So I can get and set HID reports via control transfers. Also, I can set reports via interrupt OUT transfers, but not IN.
Using USBlyzer, I diagnosed the packet stream. As soon as I attach my device, I do see two interrupt IN transfer attempts at 01:00:81 (C:I:E). If my host application reads EP 1, USBlyzer does not show any packets passing by.
I'm a bit out of options. Does anyone have a clue where to look for a fix?
Thanks,
Mark
Connection Status Device connected
Current Configuration 1
Speed Full
Device Address 3
Number Of Open Pipes 4
Device Descriptor Swinxs Game Console
Offset Field Size Value Description
0 bLength 1 12h
1 bDescriptorType 1 01h Device
2 bcdUSB 2 0200h USB Spec 2.0
4 bDeviceClass 1 00h Class info in Ifc Descriptors
5 bDeviceSubClass 1 00h
6 bDeviceProtocol 1 00h
7 bMaxPacketSize0 1 40h 64 bytes
8 idVendor 2 C251h Keil Software, Inc.
10 idProduct 2 1708h
12 bcdDevice 2 0203h 2.03
14 iManufacturer 1 04h "Swinxs BV "
15 iProduct 1 20h "Swinxs Game Console"
16 iSerialNumber 1 48h "000050020801"
17 bNumConfigurations 1 01h
Configuration Descriptor 1 Bus Powered, 300 mA
0 bLength 1 09h
1 bDescriptorType 1 02h Configuration
2 wTotalLength 2 0040h
4 bNumInterfaces 1 02h
5 bConfigurationValue 1 01h
6 iConfiguration 1 00h
7 bmAttributes 1 80h Bus Powered
 4..0: Reserved  ...00000
 5: Remote Wakeup  ..0.....  No
 6: Self Powered  .0......  No, Bus Powered
 7: Reserved (set to one)
(bus-powered for 1.0)  1.......
8 bMaxPower 1 96h 300 mA
Interface Descriptor 0/0 HID, 2 Endpoints
0 bLength 1 09h
1 bDescriptorType 1 04h Interface
2 bInterfaceNumber 1 00h
3 bAlternateSetting 1 00h
4 bNumEndpoints 1 02h
5 bInterfaceClass 1 03h HID
6 bInterfaceSubClass 1 00h
7 bInterfaceProtocol 1 00h
8 iInterface 1 80h "Swinxs HID"
HID Descriptor
0 bLength 1 09h
1 bDescriptorType 1 21h HID
2 bcdHID 2 0110h 1.10
4 bCountryCode 1 00h
5 bNumDescriptors 1 01h
6 bDescriptorType 1 22h Report
7 wDescriptorLength 2 0045h 69 bytes
Endpoint Descriptor 81 1 In, Interrupt
0 bLength 1 07h
1 bDescriptorType 1 05h Endpoint
2 bEndpointAddress 1 81h 1 In
3 bmAttributes 1 03h Interrupt
 1..0: Transfer Type  ......11  Interrupt
 7..2: Reserved  000000..
4 wMaxPacketSize 2 0001h 1 byte
6 bInterval 1 00h
Endpoint Descriptor 01 1 Out, Interrupt
0 bLength 1 07h
2 bEndpointAddress 1 01h 1 Out
4 wMaxPacketSize 2 0006h 6 bytes
6 bInterval 1 00h
Interface Descriptor 1/0 Mass Storage, 2 Endpoints
0 bLength 1 09h
2 bInterfaceNumber 1 01h
5 bInterfaceClass 1 08h Mass Storage
6 bInterfaceSubClass 1 06h SCSI Transparent Command Set
7 bInterfaceProtocol 1 50h Bulk-Only Transport
8 iInterface 1 62h "Swinxs Storage"
Endpoint Descriptor 82 2 In, Bulk, 64 bytes
0 bLength 1 07h
2 bEndpointAddress 1 82h 2 In
3 bmAttributes 1 02h Bulk
 1..0: Transfer Type  ......10  Bulk
4 wMaxPacketSize 2 0040h 64 bytes
6 bInterval 1 00h
Endpoint Descriptor 02 2 Out, Bulk, 64 bytes
0 bLength 1 07h
2 bEndpointAddress 1 02h 2 Out
6 bInterval 1 00h
Interface 0 HID Report Descriptor
Item Tag (Value) Raw Data
Usage Page (Vendor-Defined 1) 06 00 FF
Usage (Undefined) 09 00
Collection (Application) A1 01
    Usage Page (Vendor-Defined 2) 06 01 FF
    Usage (Vendor-Defined 1) 09 01
    Logical Minimum (1) 15 01
    Logical Maximum (16777215) 27 FF FF FF 00
    Report Count (1) 95 01
    Report Size (24) 75 18
    Input (Data,Var,Abs,NWrp,Lin,Pref,NNul,Bit) 81 02
    Usage (Vendor-Defined 2) 09 02
    Report Size (16) 75 10
    Usage Minimum (Vendor-Defined 1) 19 01
    Usage Maximum (Vendor-Defined 3) 29 03
    Logical Minimum (0) 15 00
    Logical Maximum (1) 25 01
    Report Count (3) 95 03
    Report Size (1) 75 01
    Report Size (5) 75 05
    Input (Cnst,Ary,Abs) 81 01
    Usage Page (Vendor-Defined 3) 06 02 FF
    Usage (Vendor-Defined 16) 09 10
    Logical Maximum (100) 25 64
    Report Size (8) 75 08
    Output (Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) 91 02
End Collection C0
