Hello All,
I am finding it really hard to perform write and read operations on the EEPROM connected to the MCU by two wires using the I2C Protocol.
I've read the data sheets, written the code exactly matching the datasheet info, but it was of no avail.
Please help me out.
My code looks something like this
void Write_Start(void) { E2P_SDA = 1; E2P_SCL = 1; delay_i2c(); E2P_SDA = 0; delay_i2c(); E2P_SCL = 0; delay_i2c(); } void Write_to_E2P(void) { unsigned char DEV_SEL_CODE = 0x0A0; unsigned char ADDR_MSB = 0x50; unsigned char ADDR_LSB = 0x05; unsigned char i; Write_Start(); for(i=7;i>=0;i--) { E2P_SDA = DEV_SEL_CODE^i; E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); } E2P_SDA = 1; E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); delay_i2c(); E2P_SCL = 0; delay_i2c(); if(E2P_SDA == 0) LED1=1; for(i=7;i>=0;i--) { E2P_SDA = ADDR_MSB^i; E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); } E2P_SDA = 1; E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); delay_i2c(); E2P_SCL = 0; delay_i2c(); if(E2P_SDA == 0) LED2=1; for(i=7;i>=0;i--) { E2P_SDA = ADDR_LSB^i; E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); } E2P_SDA = 1; E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); delay_i2c(); E2P_SCL = 0; delay_i2c(); if(E2P_SDA == 0) LED3=1; for(i=7;i>=0;i--) { E2P_SDA = current_channel^i; E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); } E2P_SDA = 1; E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); delay_i2c(); E2P_SCL = 0; delay_i2c(); if(E2P_SDA == 0) LED4=1; }
programs have comments, scribbles do not
thank you for your interest in the thread i posted. i assumed the lingo would be self explanatory. i'll put up a commented version.
well, you might want to take a look at these Erik,
1.) en.wikipedia.org/.../Computer_program 2.) www.webopedia.com/.../program.html 3.) encarta.msn.com/.../computer_program.html 4.) www.britannica.com/.../computer-program
see if you can find the words "comment" or "comments" in these page !
you could have gone easy on that..........
thanks a lot for your valuable advice captain. i dont disagree with you at all, so, i am posting my commented version right away.
/* the routine for sending a start bit for i2c initialization */ void Write_Start(void) { E2P_SDA = 1; // sda is set high initially for a Hi to Low transition E2P_SCL = 1; // scl is made high delay_i2c(); // delay of 5 micro seconds E2P_SDA = 0; // sda is driven low to complete hi to low signal delay_i2c(); // delay of 5 micro seconds E2P_SCL = 0; // scl is then made low again to complete one clock period delay_i2c(); } /* this is used to write a byte onto the eeprom at location 0x5005 */ void Write_to_E2P(void) { unsigned char DEV_SEL_CODE = 0x0A0; // device select code unsigned char ADDR_MSB = 0x50; // MSB of address unsigned char ADDR_LSB = 0x05; // LSB of address unsigned char i; // loop variable Write_Start(); // I2C START for(i=7;i>=0;i--) // transmitting from the bit 7 down to bit 0 in the loop { E2P_SDA = DEV_SEL_CODE^i; // data bit on the sda line E2P_SCL = 0; // a rising edge of the pulse to sample the sda line delay_i2c(); E2P_SCL = 1; delay_i2c(); } E2P_SDA = 1; // these lines are for the 9th clock pulse when the slave pulls the sda line low E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); delay_i2c(); E2P_SCL = 0; delay_i2c(); if(E2P_SDA == 0) // if the acknowledge is recieved then we glow an LED used for debugging on board LED1=1; /* the same story follows for the rest three bytes, which are - the address MSB and LSB and the data byte to be transferred */ for(i=7;i>=0;i--) { E2P_SDA = ADDR_MSB^i; E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); } E2P_SDA = 1; E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); delay_i2c(); E2P_SCL = 0; delay_i2c(); if(E2P_SDA == 0) LED2=1; for(i=7;i>=0;i--) { E2P_SDA = ADDR_LSB^i; E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); } E2P_SDA = 1; E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); delay_i2c(); E2P_SCL = 0; delay_i2c(); if(E2P_SDA == 0) LED3=1; for(i=7;i>=0;i--) { E2P_SDA = data_byte^i; // data_byte is a global variable E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); } E2P_SDA = 1; E2P_SCL = 0; delay_i2c(); E2P_SCL = 1; delay_i2c(); delay_i2c(); E2P_SCL = 0; delay_i2c(); if(E2P_SDA == 0) LED4=1; }
Excuse me, Ms. Sandy, were you not asking for help? Do you really believe people will me more interested in helping you if you insult them?
Well, whatever that was, started and ended with my reply, now, Please, assist me!
Sandy Sandy, I agree, started and ended
Unfortunately, the Monkey-dung hit the fan here, and I can't spend my time dealing with your issue at the moment.
I have some "race-conditions" to settle asap (meaning I'll be working over the weekend).
I'm sure some of our talented contributors will help out if they can get past the 'hostility' issues.
Hope all goes well.
--Cpt. Vince Foster 2nd Cannon Place Fort Marcy Park, VA
why on earth use that chip. The P89C66x is identical PLUS it has hardware IIC, the code for which can be obtained from the CodeArchitect.
Bit banged IIC makes EVERYTHING ELSE come to a total standstill for an excessive time. Hardware IIC just generates an interrupt for each byte.
i am using a DIP Package. My board is designed for that.
I do wish forums could filter the I wouldn't start from there style answers.
But many "I wouldn't start from there" do bring forward good information.
In this case: It is normally better to use a controller with I2C than to implement it in software. And today, there is no correlation between controller price and the availability of a I2C controller.
Another interesting thing is the answer we got: "i am using a DIP Package. My board is designed for that."
Quite a number of 8051 chips are available in a DIP package. Quite a number of development boards with 40-pin DIP sockets are intended for use with quite a number of different 8051 chips, as long as care is taken with supply voltages, crystal frequency and similar.
A much better reason for not considering alternatives would have been: "The controller is soledred on my development board, and I don't have the equipment to replace it with another, and can't afford buying another development board."
Another good reason for staying with bit-banging would have been: "My assignment is to implement a software-only solution, to prove that I understand the protocol."
P89C66x is available in DIP
if someone post I am trying to shoot an elephan with a BB gun, what would your answer be?
eRIK
It certainly wouldn't be "You're an idiot! Why did you choose to go to Africa? You should have chosen Belgium instead".
Your post was the first containing the word "idiot". Return back to the previous posts, and read them again.
Then return back with a list of the amount of bad advice you found.
I was fully aware of that!
I'm directly expressing the tone of what was originally implied.
But why do you think this is a less worthy contribution? What not to do is sometimes a good guideline (try this: "don't shoot elephants"). Overly touchy, Jenit?
You're somehow continuing to miss the point, which is not a comment on the merit of the contribution but the pig-ignorant tone with which it was presented. Jenit probably hasn't been reading this forum for long enough to realise that a number of the regular contributors suffer from varying degrees of ignorance and/or delusion.
