I get this error when compiling Adam Dunkels uIP adapted to LPC-2124 board. fs.c contains the functions to open files (fs_open) and fsdata.c contains the html code of these files. I'm completely stuck with this, I would apreciate any help.
Thanks.
error log: uIP-2124.axf: Error: L6200E: Symbol file_cgi_files multiply defined (by fsdata.o and fs.o). uIP-2124.axf: Error: L6200E: Symbol file_cgi_stats multiply defined (by fsdata.o and fs.o). uIP-2124.axf: Error: L6200E: Symbol file_cgi_tcp multiply defined (by fsdata.o and fs.o). uIP-2124.axf: Error: L6200E: Symbol file_img_bg_png multiply defined (by fsdata.o and fs.o). uIP-2124.axf: Error: L6200E: Symbol file_about_html multiply defined (by fsdata.o and fs.o). uIP-2124.axf: Error: L6200E: Symbol file_control_html multiply defined (by fsdata.o and fs.o). uIP-2124.axf: Error: L6200E: Symbol file_404_html multiply defined (by fsdata.o and fs.o). uIP-2124.axf: Error: L6200E: Symbol file_files_footer_plain multiply defined (by fsdata.o and fs.o). uIP-2124.axf: Error: L6200E: Symbol file_files_header_html multiply defined (by fsdata.o and fs.o). uIP-2124.axf: Error: L6200E: Symbol file_index_html multiply defined (by fsdata.o and fs.o). uIP-2124.axf: Error: L6200E: Symbol file_stats_footer_plain multiply defined (by fsdata.o and fs.o). uIP-2124.axf: Error: L6200E: Symbol file_stats_header_html multiply defined (by fsdata.o and fs.o). uIP-2124.axf: Error: L6200E: Symbol file_tcp_footer_plain multiply defined (by fsdata.o and fs.o). uIP-2124.axf: Error: L6200E: Symbol file_tcp_header_html multiply defined (by fsdata.o and fs.o).
Look at the error messages, read them carefully, and think what they are telling you!
eg,
That's telling you that both fsdata.o and fs.o contain a definition of file_cgi_files
Now, fsdata.o and fs.o are the Object files produced by compiling fsdata.c and fs.c respectively.
Therefore, look at the source code in fsdata.c and fs.c to see if they do, in fact, both contain a definition of file_cgi_files - then decide which one to keep, and which to remove.
First of all thank for your reply,
I have been checked in both files (fs.c and fsdata.c) if I had defined the same file_cgi_files in both, but as far i can see I didnÂ't. I know that I only have to declare it in one of them and make a reference as extern-declare in the other. But I canÂ't see where is the mistake because I only define it in fsdata.c
I send the code just in case you donÂ't mind to have a look at it, IÂ've been stuck with it for a week, any help apreciated.
Here is the code of fs.c: #include "uip.h" #include "httpd.h" #include "fs.h" #include "fsdata.h"
#define NULL (void *)0 #include "fsdata.c"
#ifdef FS_STATISTICS #if FS_STATISTICS == 1 static u16_t count[FS_NUMFILES]; #endif /* FS_STATISTICS */ #endif /* FS_STATISTICS */
/*-----------------------------------------------------------------------------------*/ static u8_t fs_strcmp(const char *str1, const char *str2) { u8_t i; i = 0; loop:
if(str2[i] == 0 || str1[i] == '\r' || str1[i] == '\n') { return 0; }
if(str1[i] != str2[i]) { return 1; }
++i; goto loop; } /*-----------------------------------------------------------------------------------*/ int fs_open(const char *name, struct fs_file *file) { #ifdef FS_STATISTICS #if FS_STATISTICS == 1 u16_t i = 0; #endif /* FS_STATISTICS */ #endif /* FS_STATISTICS */ struct fsdata_file_noconst *f;
for(f = (struct fsdata_file_noconst *)FS_ROOT; f != NULL; f = (struct fsdata_file_noconst *)f->next) {
if(fs_strcmp(name, f->name) == 0) { file->data = f->data; file->len = f->len; #ifdef FS_STATISTICS #if FS_STATISTICS == 1 ++count[i]; #endif /* FS_STATISTICS */ #endif /* FS_STATISTICS */ return 1; } #ifdef FS_STATISTICS #if FS_STATISTICS == 1 ++i; #endif /* FS_STATISTICS */ #endif /* FS_STATISTICS */
} return 0; } /*-----------------------------------------------------------------------------------*/ void fs_init(void) { #ifdef FS_STATISTICS #if FS_STATISTICS == 1 u16_t i; for(i = 0; i < FS_NUMFILES; i++) { count[i] = 0; } #endif /* FS_STATISTICS */ #endif /* FS_STATISTICS */ } /*-----------------------------------------------------------------------------------*/ #ifdef FS_STATISTICS #if FS_STATISTICS == 1 u16_t fs_count (char *name) { struct fsdata_file_noconst *f; u16_t i;
i = 0; for(f = (struct fsdata_file_noconst *)FS_ROOT; f != NULL; f = (struct fsdata_file_noconst *)f->next) {
if(fs_strcmp(name, f->name) == 0) { return count[i]; } ++i; } return 0; } #endif /* FS_STATISTICS */ #endif /* FS_STATISTICS */
and fsdata.c code:(only with file_cgi_files definition)
#include "fsdata.h" #define NULL (void *)0 static const char data_cgi_files[] = { /* /cgi/files */ 0x2f, 0x63, 0x67, 0x69, 0x2f, 0x66, 0x69, 0x6c, 0x65, 0x73, 0, 0x23, 0x20, 0x54, 0x68, 0x69, 0x73, 0x20, 0x73, 0x63, 0x72}
const struct fsdata_file file_cgi_files[] = {{NULL, data_cgi_files, data_cgi_files + 11, sizeof(data_cgi_files) - 11}};
Please read & follow the instructions for posting source code - and pay attention to the 'Preview'
Attention to detail is key in this game!
"I know that I only have to declare (sic) it in one of them and make a reference as extern-declare in the other."
To be precise, you need to define it exactly once - and then use extern declarations as often as you like elsewhere.
You haven't shown your header's contents - are you sure it doesn't contain a definition...?
Sorry for mistakes,
I am going to check header files carefulle and try to resolve these problems, anyway I post them (headers files) just in case someone can help me:
Thank you so much for your help.
fs.h:
#ifndef __FS_H__ #define __FS_H__ #include "uip.h" /** * An open file in the read-only file system. */ struct fs_file { char *data; /**< The actual file data. */ int len; /**< The length of the file data. */ }; /** * Open a file in the read-only file system. * * \param name The name of the file. * * \param file The file pointer, which must be allocated by caller and * will be filled in by the function. */ int fs_open(const char *name, struct fs_file *file); #ifdef FS_STATISTICS #if FS_STATISTICS == 1 u16_t fs_count(char *name); #endif /* FS_STATISTICS */ #endif /* FS_STATISTICS */ /** * Initialize the read-only file system. */ void fs_init(void); #endif /* __FS_H__ */
fsdata.h
#ifndef __FSDATA_H__ #define __FSDATA_H__ #include "uipopt.h" struct fsdata_file { const struct fsdata_file *next; const char *name; const char *data; const int len; #ifdef FS_STATISTICS #if FS_STATISTICS == 1 u16_t count; #endif /* FS_STATISTICS */ #endif /* FS_STATISTICS */ }; struct fsdata_file_noconst { struct fsdata_file *next; char *name; char *data; int len; #ifdef FS_STATISTICS #if FS_STATISTICS == 1 u16_t count; #endif /* FS_STATISTICS */ #endif /* FS_STATISTICS */ }; #endif /* __FSDATA_H__ */
"I post them (headers files) just in case someone can help me"
The text "file_cgi_files" occurs nowhere in either of those files - so the problem must, obviously, lie elsewhere...
there must be a way to implement some filter that would prevent posting of a reply/thread is it contains unformatted code...! That will save you so much heart ache, Andy ;-)
I think it would actually be quite hard to make an effective filter that didn't make too many "false hits"...?
But I still say it's symptomatic of an underlying problem: the instructions are very clearly stated; anyone who's being slack enough to miss them - and to not even notice in the preview - has probably also missed important details about their project for the very same reason
As I said earlier, Attention to detail is key in this game!
