I got the question about volatile variebles and eeprom memory. (I use C and IDE)
First of all, I have a program that has to remember a variable's value even if I reset the thing (this value changes between 0 - 9 so it is an unsigned char). The details and the program is below ;
*counter is my variable that I change value via interrupt and push button *counter is my variable that microcontroller has to remember after reset *counter is my variable that can be changed by both main and interrupt
---------------------------------------------------------------- volatile unsigned char counter; ..... ..... void interrupt() { counter++; Delay_ms(150); if(counter == 10) counter=0; while(bit is zero); Delay_ms(20); ..... ..... SFRA=0xD0; } void main() { for(; { if(counter == 0) { .....program writes 7 seg the value of counter } if(counter == 1) { .....program writes 7 seg the value of counter } if(counter == 2) { .....program writes 7 seg the value of counter } if(counter == 3) { .....program writes 7 seg the value of counter } if(counter == 4) { .....program writes 7 seg the value of counter } if(counter == 5) { .....program writes 7 seg the value of counter } if(counter == 6) { .....program writes 7 seg the value of counter } if(counter == 7) { ......program writes 7 seg the value of counter } if(counter == { ........program writes 7 seg the value of counter } if(counter == 9) { ......program writes 7 seg the value of counter } } } Now, this program does not work properly it loses the value of counter. I got two choices; 1. declaring counter variable as a volatile (but I could not succeed) 2. using eeprom memory but this will increase my loop time. Please help me I am confused.
eeprom memory. WHICH? built-in/IIC/SPI/parallel/serial/ (I use C and IDE) irrelevant
The "volatile" keyword has nothing to do with a variable surviving a reset. It just informs the compiler that some unknown external force may modify the variable at any time, so the compiler may not assume that it can keep a copy of the variable in a register and reuse multiple times.
For nonvolatile storage, i.e. data that should be kept even if the processor is reset or after a power loss, you must use EEPROM, flash, battery-backed RAM, FRAM or similar, i.e. you must use a memory type that is capable of retaining data when your equipment is not powered.
