I am trying to build a counter using an ADUC7024. Basically I want Timer0 to cause a global interrupt every 10ms. Timer1 should be counting my input TTL pulses.
Every time it interrupts, I want the DAC to output a voltage proportional to the number of counts on Timer1 in that 10ms period.
Here is my counter.c file
#include<ADuC7024.h> void IRQ_Handler(void) ; int main (void) { T0LD = 0x3FC0; // Counter Value T0CON = 0xC8; // Enabled,Periodic,Binary and CLK/256 T1LD = 0x00000000; // Load zero to timer one initial value T1CON = 0x00000780; // Enabled,count P0.6 IRQ = IRQ_Handler; // Specify Interrupt Service Rountine IRQEN = RTOS_TIMER_BIT; // Enable Timer0 IRQ DAC0CON = 0x13; DAC0DAT = 0x0FFF0000; while (1) { } } void IRQ_Handler(void) { DAC0DAT = T1VAL << 16; T1CON ^= 0x00000040; T1CON ^= 0x00000040; if ((IRQSTA & 0x00000004) != 0) // Timer0 IRQ? { GP4DAT ^= 0x00040000;// Complement P4.2 DAC0DAT = T1VAL << 16; T0CLRI = 0x1; // Clear Timer IRQ IRQCLR = 0x00000004; } return ; }
And I am using the default ADUC702x.s file. I know I need to change something with the IRQ Handlers but I don't know what. I've checked the boards and can't find anything usable for me.
Now the problem I'm getting is as my response when I build it.
Build target 'ADuC7024 Flash' assembling ADuC702x.s... compiling counter.c... linking... .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol DAbt_Handler (referred from aduc702x.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol FIQ_Handler (referred from aduc702x.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol PAbt_Handler (referred from aduc702x.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol Undef_Handler (referred from aduc702x.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol IRQ (referred from counter.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_irq_ack_lock (referred from rt_hal.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol tsk_unlock (referred from rt_hal.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_stackinfo (referred from rt_hal.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_stk_overflow (referred from rt_hal.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_tmr_force_irq (referred from rt_system.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_tmr_inspect_cnt (referred from rt_system.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_tmr_inspect_ovf (referred from rt_system.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol m_tmr (referred from rt_task.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol mp_stk (referred from rt_task.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol mp_stk_size (referred from rt_task.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol mp_tcb (referred from rt_task.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol mp_tcb_size (referred from rt_task.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol mp_tmr_size (referred from rt_task.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_active_TCB (referred from rt_task.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_idle_demon (referred from rt_task.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_maxtaskrun (referred from rt_task.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_rrobin (referred from rt_task.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_tmr_init (referred from rt_task.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol tsk_lock (referred from rt_task.o). .\Flash\Counter_Test.axf: Error: L6218E: Undefined symbol os_tmr_call (referred from rt_timer.o). Target not created
Can anyone help? email is j.d.ellis@tudelft.nl
You have selected an RTX Kernel operating system in Target Options. Change this selection to None and your problems will most likely go away.
No, I've deselected that option. I should just be doing a normal *.hex compilation. When I deselect the RTX option, most of these errors go away.
I still have the error with the IRQ not working properly. If I comment out the line
IRQ = IRQ_Handler;
Then I don't get any errors, but when I run the system, I get no interrupts.
The Dimmer example from MDK is a good reference how the interrupts are used with ADuC7024. This example is located in boards folder.
..\ARM\Boards\ADI\ADuC702x\Dimmer
