What's wrong with this code
Well my program is a car security system which detects intrusion ,fire,gas using 4 sensors and sends an sms via GSM modem. Given below is my code which is in BASCOM software which when compiled given numerous errors. CAn you tell me what could be the problem???
Also im using 89S52 microcontroller
$crystal = 11059200
Sw1 Alias P0.0
Sw2 Alias P0.1
Sw3 Alias P0.2
Sw4 Alias P0.3
Sw5 Alias P0.4
Led0 Alias P1.0
Led1 Alias P1.1
Led2 Alias P1.2
Led3 Alias P1.3
Led4 Alias P1.4
Bz Alias P3.6
Relay Alias P3.7
Main:
Led0 = 1
Bz = 0
Relay = 0
Led1 = 0
Led2 = 0
Led3 = 0
Led4 = 0
Read:
X =(q0)p0
X =(q1)p0
X =(q2)p0
X =(q3)p0
Select Case X(value)
Case 1:
Sms1:
Led0 = 0
Led1 = 1 Led2 = 0 Led3 = 0 Led4 = 0
Bz = 1 Relay = 1
Print "AT+CMGS=1,";
Waitms 100
Print "9967863284"; Wait 3
Print Chr(34)
Led0 = 1
Led1 = 0 Led2 = 0 Led3 = 0 Led4 = 0
Bz = 0 Relay = 0 Goto Read
Case 2:
Sms2:
Led0 = 0 Led1 = 0 Led2 = 1 Led3 = 0 Led4 = 0
Bz = 1 Relay = 1
Print "AT+CMGS=2,";
Waitms 100
Print Chr(34)
Led0 = 1
Case 4:
Sms3:
Led0 = 0 Led1 = 0 Led2 = 0 Led3 = 1 Led4 = 0
Bz = 1 Relay = 1
Print "AT+CMGS=3,";
Waitms 100
Print Chr(34)
Led0 = 1
Case 8:
Sms4:
Led0 = 0 Led1 = 0 Led2 = 0 Led3 = 0 Led4 = 1
Bz = 1 Relay = 1
Print "AT+CMGS=4,";
Waitms 100
Print Chr(34)
Led0 = 1
End Select
Goto Main
End
  • "my code which is in BASCOM"
    Your most fundamental error, then, is in posting it to an entirely irrelevant forum!
    BASCOM is not a Keil product, is it?!
    See: http://www.keil.com/forum/
  • CAn you tell me what could be the problem???
    The problem could be that your program has syntax errors.
    I can tell you the problems of your posting more precisely:
    1. BASCOM is not a Keil product. This is a forum about Keil products, not about '51 stuff in general.
    Without knowing what errors you get, how is anyone supposed to diagnose the problems without first getting BASCOM itself and then compiling your program ? "it gives numerous errors" is not useful information for diagnosis, and therefore will only yield answers that are correct, but not useful.
    3. You did not read the "Tips for posting messages", or you read and ignored them. They appear right above the box where you type in your posting, so they are almost impossible to miss. Following them is considered good etiquette and people are much more likely to help you if you do.
    http://www.keil.com/forum/tips.asp
