hi. I copy some codes from ADS and then plaster them to keil as test.s file.when I compile them.some errors: assembling test.s... word.s(1): error A65: IDENTIFIER EXPECTED word.s(5): error A116: NO CURRENT 'AREA' word.s(7): error A116: NO CURRENT 'AREA' word.s(8): error A116: NO CURRENT 'AREA' word.s(9): error A116: NO CURRENT 'AREA' word.s(10): error A116: NO CURRENT 'AREA' word.s(12): error A116: NO CURRENT 'AREA' word.s(13): error A116: NO CURRENT 'AREA' word.s(14): error A116: NO CURRENT 'AREA' word.s(15): error A116: NO CURRENT 'AREA' word.s(16): error A116: NO CURRENT 'AREA' word.s(18): error A116: NO CURRENT 'AREA' word.s(19): error A116: NO CURRENT 'AREA' word.s(20): error A116: NO CURRENT 'AREA' word.s(21): error A116: NO CURRENT 'AREA' word.s(25): error A9: SYNTAX ERROR word.s(25): error A9: SYNTAX ERROR word.s(26): error A9: SYNTAX ERROR word.s(26): error A9: SYNTAX ERROR WHY?I just kown how them work.there are the source codes.
AREA ARMex, CODE, READONLY ; name this block of code ENTRY ; mark first instruction ; to execute start MOV r0, #10 ; Set up parameters MOV r1, #3 ADD r0, r0, r1 ; r0 = r0 + r1 stop MOV r0, #0x18 ; angel_SWIreason_ReportException LDR r1, =0x20026 ; ADP_Stopped_ApplicationExit SWI 0x123456 ; ARM semihosting SWI END ; Mark end of file
Download the current version of the MDK-ARM Eval Version. https://http://www.keil.com/demo/eval/arm.htm
can't work. error: --- Error: can't execute 'C:\Program Files\ARM\ADSV1_2\ArmAsm'
http://www.keil.com/download/docs/314.asp
