Hello, I don't know how to process with this error when linking a new Projeckt. Could anyone has a suggestion? Best regards -Emeric *** WARNING L23: UNRESOLVED EXTERNAL SYMBOLS *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: xSerialPortInitMinimal?T ADDRESS: 00081C78H *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: xSerialPutChar?T ADDRESS: 00081D06H *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: xSerialGetChar?T ADDRESS: 00081D78H *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: xSerialGetChar?T ADDRESS: 00081DD2H Program Size: data=6154 const=281 code=9248
REFERENCE MADE TO UNRESOLVED EXTERNAL well, thatb means that you refer to an external that is not defined. SURPRISE If any module linked refer to anything declared but not defined in that module, another module that defines that variable or whatever must be linked in. Erik
"that means that you refer to an external that is not defined. SURPRISE" Specifically, the definitions were missing for the following symbols: xSerialPortInitMinimal xSerialPutChar xSerialGetChar xSerialGetChar
Thank you very much. I have done the required changes, and every things is going well Thank you -Emeric
