Hi, Using: Keil uvision3 with Infineon XC866 Easy kit development board. I am trying to write a little menu function to controller the PWM generation via key stoke selections. The first few keystrokes are implemented and I can see the PWM signal changing. Then the micro hangs up. Not sure what is wrong !? Here is the code:
#include "MAIN.H" void message( char *pucMessage ); void MAIN_vInit(void) { /// Initialization of module 'UART (Serial Interface)' UART_vInit(); /// Initialization of module 'Capture / Compare Unit 6 (CCU6)' CC6_vInit(); // Interrupt Priority IP = 0x00; // load Interrupt Priority Register IPH = 0x00; // load Interrupt Priority High Register IP1 = 0x00; // load Interrupt Priority 1 Register IPH1 = 0x00; // load Interrupt Priority 1 High Register // globally enable interrupts EA = 1; } // End of function MAIN_vInit void main(void) { char key; MAIN_vInit(); message("\n\n\xd Welcome to MENU : PWM Control"); message("\n\xd Please select on of the following:"); message("\n\xd 1 -- 1.00 ratio"); message("\n\xd 2 -- 0.75 ratio"); message("\n\xd 3 -- 0.50 ratio"); message("\n\xd 4 -- 0.25 ratio"); message("\n\xd 5 -- 0.00 ratio"); message("\n\xd Thank you for using XC866 \n\n"); while(1) { while(!RI){}; // Wait for keystroke key = SBUF; if(key == '1') { message("\xd 1 -- 1.00 ratio"); CCU6_PAGE = 0x00; // switch to page 0 CCU6_CC60SRL |= 0x00; CCU6_CC60SRH |= 0x00; CCU6_TCTR4L |= 0x40; // enable shadow transfer } if(key == '2') { message("\xd 2 -- 0.75 ratio"); CCU6_PAGE = 0x00; // switch to page 0 CCU6_CC60SRL |= 0x00; CCU6_CC60SRH |= 0x40; CCU6_TCTR4L |= 0x40; // enable shadow transfer } if(key == '3') { message("\xd 3 -- 0.50 ratio"); CCU6_PAGE = 0x00; // switch to page 0 CCU6_CC60SRL |= 0x00; CCU6_CC60SRH |= 0x80; CCU6_TCTR4L |= 0x40; // enable shadow transfer } if(key == '4') { message("\xd 4 -- 0.25 ratio"); CCU6_PAGE = 0x00; // switch to page 0 CCU6_CC60SRL |= 0x00; CCU6_CC60SRH |= 0xC0; CCU6_TCTR4L |= 0x40; // enable shadow transfer } if(key == '5') { message("\xd 5 -- 0.00 ratio"); CCU6_PAGE = 0x00; // switch to page 0 CCU6_CC60SRL |= 0xFF; CCU6_CC60SRH |= 0xFF; CCU6_TCTR4L |= 0x40; // enable shadow transfer } RI = 0; // Reset RI } } // End of function main void message( char *pucMessage ) { // while the character is not 0 while (*pucMessage) { SBUF = *pucMessage++; while (TI == 0) {;} TI = 0; } return; }
I note that you are always OR-ing bits into CCU6_CC60SRL and CCU6_CC60SRH - so you never actually clear any bits in these registers. Is this really what you want? I don't know this particular chip, but it strikes me that you're going to end up with all bits set in both registers, and no way to clear any bits. Again, is this what you really want? In other words, Should you be using '=' rather than '|=' for these two registers? As an aside, don't you think a switch would be more appropriate here - or even a lookup table?
I changed the if statements to case and stoping or-ing the values. But still the micro hangs up after a few changes. I also noticed the Uart is not always updating the screen. Could it be that i need a few delay's between selection and updating. Here is the code as now:
while(!RI){}; // Wait for keystroke key = SBUF; switch(key) { case '1': message("\xd 1 -- 0.10 ratio"); CCU6_PAGE = 0x00; // switch to page 0 CCU6_CC60SRL = 0x66; CCU6_CC60SRH = 0xE6; CCU6_TCTR4L = 0x40; // enable shadow transfer break; case '2': message("\xd 2 -- 0.25 ratio"); CCU6_PAGE = 0x00; // switch to page 0 CCU6_CC60SRL = 0x00; CCU6_CC60SRH = 0x40; CCU6_TCTR4L = 0x40; // enable shadow transfer break; case '3': message("\xd 3 -- 0.50 ratio"); CCU6_PAGE = 0x00; // switch to page 0 CCU6_CC60SRL = 0x00; CCU6_CC60SRH = 0x80; CCU6_TCTR4L = 0x40; // enable shadow transfer break; case '4': message("\xd 4 -- 0.75 ratio"); CCU6_PAGE = 0x00; // switch to page 0 CCU6_CC60SRL = 0x00; CCU6_CC60SRH = 0xC0; CCU6_TCTR4L = 0x40; // enable shadow transfer break; case '5': message("\xd 5 -- 0.9O ratio"); CCU6_PAGE = 0x00; // switch to page 0 CCU6_CC60SRL = 0x9A; CCU6_CC60SRH = 0x19; CCU6_TCTR4L = 0x40; // enable shadow transfer break; } RI = 0;
which version of the DCORE51.DLL are you using? Reinhard
"Then the micro hangs up." How do you know that the whole micro hangs up? Are you sure that it's not just the serial input that stops working, or the PWM, or...?
Hi, I am using version 2.45.8.0 or 2.45h (both codes are mentioned under version) of the DCore51.dll file. Should I be using another ? Both the serial port and PWM stops working. The message in the case '1' loop for example is not written out over the serial link anymore and the pwm signal does not change when I push another keystroke. I do not know for sure which (serial input/output or the pwm) stops working first. Could it be that I need to insert a delay function for the pwm change to be affected and the serial write to be complete before hitting another keystroke. I would think the pwm change would be quite quick even in the center align mode.
Hello Kobus, is your problem solved now? I would think about the UART as evil, since the CAPCOM part seems good. But I do not know your setup of the CAPCOM. I did a similar in center aligned mode, but with timer T2 to change the PWM's, that works fine. Think (or better) take care of your period value, because if the compare values are not in the range no shadow transfer will take place anymore and that's why your new pwm values will never become active. Thus with reference of counting rules. Stefan
Not yet. I'll check on your suggestions.
