PWM with menu control - hangs up
Using: Keil uvision3 with Infineon XC866 Easy kit development board.
I am trying to write a little menu function to controller the PWM generation via key stoke selections. The first few keystrokes are implemented and I can see the PWM signal changing. Then the micro hangs up.
Not sure what is wrong !?
Here is the code:
#include "MAIN.H"
void message( char *pucMessage );
void MAIN_vInit(void)
  ///  Initialization of module 'UART (Serial Interface)'
  UART_vInit();
  ///  Initialization of module 'Capture / Compare Unit 6 (CCU6)'
  CC6_vInit();
  //   Interrupt Priority
  IP            =  0x00;         // load Interrupt Priority Register
  IPH           =  0x00;         // load Interrupt Priority High Register
  IP1           =  0x00;         // load Interrupt Priority 1 Register
  IPH1          =  0x00;         // load Interrupt Priority 1 High Register
  //   globally enable interrupts
  EA            =  1;
} //  End of function MAIN_vInit
void main(void)
  char key;
  MAIN_vInit();
	message("\n\n\xd Welcome to MENU : PWM Control");
	message("\n\xd Please select on of the following:");
	message("\n\xd 1 -- 1.00 ratio");
	message("\n\xd 2 -- 0.75 ratio");
	message("\n\xd 3 -- 0.50 ratio");
	message("\n\xd 4 -- 0.25 ratio");
	message("\n\xd 5 -- 0.00 ratio");
	message("\n\xd Thank you for using XC866 \n\n");
  while(1)
	while(!RI){};	 // Wait for keystroke
	key = SBUF;
	if(key == '1')
		message("\xd 1 -- 1.00 ratio");
        CCU6_PAGE = 0x00; // switch to page 0
		CCU6_CC60SRL |= 0x00;
		CCU6_CC60SRH |= 0x00;
		CCU6_TCTR4L |= 0x40; // enable shadow transfer
	if(key == '2')
		message("\xd 2 -- 0.75 ratio");
		CCU6_CC60SRH |= 0x40;
	if(key == '3')
		message("\xd 3 -- 0.50 ratio");
		CCU6_CC60SRH |= 0x80;
	if(key == '4')
		message("\xd 4 -- 0.25 ratio");
		CCU6_CC60SRH |= 0xC0;
	if(key == '5')
		message("\xd 5 -- 0.00 ratio");
		CCU6_CC60SRL |= 0xFF;
		CCU6_CC60SRH |= 0xFF;
	RI = 0;	 // Reset RI
} //  End of function main
 // while the character is not 0
 while (*pucMessage)
  SBUF = *pucMessage++;
  while (TI == 0) {;}
  TI = 0;
 return;
