Improper fixup problem in library when using compact model
my code passes compilation fine when using small or large models. however when changing the project to use compact model, I get the following errors, (which seem like library bugs) (???):
linking...
*** ERROR L121: IMPROPER FIXUP
    MODULE:  C:\KEIL\C51\LIB\C51FPC.LIB (PRINTF)
    SEGMENT: ?PR?PRINTF?PRINTF
    OFFSET:  0068H
    MODULE:  C:\KEIL\C51\LIB\C51FPC.LIB (LOG)
    SEGMENT: ?PR?LOG?LOG
    OFFSET:  0087H
    OFFSET:  00AFH
    OFFSET:  00C8H
    OFFSET:  00D5H
    OFFSET:  00F0H
    OFFSET:  010DH
*** APPLICATION REQUIRES RE-TRANSLATIONS! ***
Program Size: data=133.7 xdata=1795 code=15338
Target not created
can you please advise ?
Thanks,
Amit Alon.
