lcd PROBLEM
hi all i am a bit stuck in a problem .
i am using a LAMPEX 24200(HD44780 clone) lcd and trying to interface it with AT89C51 . my problem is i am not able to understand where my problem lies , it seems to me after many hardware tests that it is ok , but software is also ok (as per me )then why is my lcd not functioning .the lcd is ok (tested it )
the code is :
cseg at 000h
DB0 EQU P2.0
DB1 EQU P2.1
DB2 EQU P2.2
DB3 EQU P2.3
DB4 EQU P2.4
DB5 EQU P2.5
DB6 EQU P2.6
DB7 EQU P2.7
RS EQU P3.2
RW EQU P3.3
EN EQU P3.4
DATA_BUS EQU P2
; FUNTION_SET EQU #38h
org 000h
mov R2,#200
timer: mov R3,#100 ; thats a delay of more than 20 mSeconds
djnz R3,$
dec R2
cjne R2,#0,timer
jmp LCD_INIT ;KSCAN
; LCD INITIALIZATION
LCD_INIT: setb EN ; Enabling the LCD for Access
clr RS ; Setting it for Instruction transfer mode
clr RW ; Setting it as ins. write mode
mov DATA_BUS,#38h ; Sending the instruction "Function set" specifying DL=1(8 Bits),N=1(2 Line),F=0(5x7 Dots)
nop
nop
nop
clr EN ; Start the transfer
call timer0
nop
nop
nop
call timer0
nop
nop
nop
;call LCD_WAIT
call timer0
nop
nop
nop
;call LCD_WAIT
call timer0
setb EN ;
clr RS ; Instruction Mode
clr RW ;
mov DATA_BUS,#0Fh ; Sending the instruction set 00001111 = 0Fh -> 1DCB -> D= Dislpay On,C= Cursor On,B= Blinking Cursor On .
nop
nop
nop
clr EN ;
;call LCD_WAIT
call timer0
setb EN
clr RS
clr RW
mov DATA_BUS,#1h ; Sending the instruction set 00000001 = 01h -> To clear the Display
nop
nop
nop
clr EN ;
;call LCD_WAIT
call timer0
setb EN
clr RS
clr RW
mov DATA_BUS,#2h ; Sending the instruction set 00000010 = 02h -> To return the cursor to the home position
nop
nop
nop
clr EN ;
;call LCD_WAIT
call timer0
setb EN
clr RS
clr RW
mov DATA_BUS,#6h ; Sets the entry mode i.e the cursor always increments
nop
nop
nop
clr EN ;
;call LCD_WAIT
call timer0
setb EN
clr RS
clr RW
mov DATA_BUS,#14h ; Sets the shift mode to 0 i.e cursor move ,R/L to right shift .
nop
nop
nop
clr EN ;
;call LCD_WAIT
call timer0
setb EN
clr RS
clr RW
mov DATA_BUS,#80h ; sets the DDRAM address to 00H
nop
nop
nop
clr EN ;
;call LCD_WAIT
call timer0
; Initialization Over
call LCD_CLEAR
call LCD_WRITE
jmp $
LCD_WAIT:
call timer0
Ret
setb EN ;
clr RS ;
setb RW ;
mov DATA_BUS,0FFh;
nop
nop
nop
clr EN ;
JB DB7,LCD_WAIT
clr EN;
clr RW;
ret
LCD_CLEAR: setb EN
clr RS
clr RW
mov DATA_BUS,#1
nop
nop
nop
clr EN
call LCD_WAIT
ret
LCD_WRITE: setb EN
setb RS
clr RW
mov A,#'B'
mov DATA_BUS,A
nop
nop
nop
clr EN
call LCD_WAIT
setb EN
setb RS
clr RW
mov A,#'O'
mov DATA_BUS,A
nop
nop
nop
clr EN
call LCD_WAIT
setb EN
setb RS
clr RW
mov A,#'U'
mov DATA_BUS,A
nop
nop
nop
clr EN
call LCD_WAIT
ret
timer0: mov R2,#50
timer1: mov R3,#100 ; thats a delay of more than 5 mSeconds
djnz R3,$
dec R2
cjne R2,#0,timer1
ret
end
dejan can you help !!
with regards
som
