hi all i am a bit stuck in a problem . i am using a LAMPEX 24200(HD44780 clone) lcd and trying to interface it with AT89C51 . my problem is i am not able to understand where my problem lies , it seems to me after many hardware tests that it is ok , but software is also ok (as per me )then why is my lcd not functioning .the lcd is ok (tested it ) the code is : cseg at 000h DB0 EQU P2.0 DB1 EQU P2.1 DB2 EQU P2.2 DB3 EQU P2.3 DB4 EQU P2.4 DB5 EQU P2.5 DB6 EQU P2.6 DB7 EQU P2.7 RS EQU P3.2 RW EQU P3.3 EN EQU P3.4 DATA_BUS EQU P2 ; FUNTION_SET EQU #38h org 000h mov R2,#200 timer: mov R3,#100 ; thats a delay of more than 20 mSeconds djnz R3,$ dec R2 cjne R2,#0,timer jmp LCD_INIT ;KSCAN ; ;************************************************************************************** ; ; LCD INITIALIZATION ; ;************************************************************************************** LCD_INIT: setb EN ; Enabling the LCD for Access clr RS ; Setting it for Instruction transfer mode clr RW ; Setting it as ins. write mode mov DATA_BUS,#38h ; Sending the instruction "Function set" specifying DL=1(8 Bits),N=1(2 Line),F=0(5x7 Dots) nop nop nop clr EN ; Start the transfer call timer0 setb EN ; Enabling the LCD for Access clr RS ; Setting it for Instruction transfer mode clr RW ; Setting it as ins. write mode mov DATA_BUS,#38h ; Sending the instruction "Function set" specifying DL=1(8 Bits),N=1(2 Line),F=0(5x7 Dots) nop nop nop clr EN ; Start the transfer call timer0 setb EN ; Enabling the LCD for Access clr RS ; Setting it for Instruction transfer mode clr RW ; Setting it as ins. write mode mov DATA_BUS,#38h ; Sending the instruction "Function set" specifying DL=1(8 Bits),N=1(2 Line),F=0(5x7 Dots) nop nop nop clr EN ; Start the transfer ;call LCD_WAIT call timer0 setb EN ; Enabling the LCD for Access clr RS ; Setting it for Instruction transfer mode clr RW ; Setting it as ins. write mode mov DATA_BUS,#38h ; Sending the instruction "Function set" specifying DL=1(8 Bits),N=1(2 Line),F=0(5x7 Dots) nop nop nop clr EN ; Start the transfer ;call LCD_WAIT call timer0 setb EN ; clr RS ; Instruction Mode clr RW ; mov DATA_BUS,#0Fh ; Sending the instruction set 00001111 = 0Fh -> 1DCB -> D= Dislpay On,C= Cursor On,B= Blinking Cursor On . nop nop nop clr EN ; ;call LCD_WAIT call timer0 setb EN clr RS clr RW mov DATA_BUS,#1h ; Sending the instruction set 00000001 = 01h -> To clear the Display nop nop nop clr EN ; ;call LCD_WAIT call timer0 setb EN clr RS clr RW mov DATA_BUS,#2h ; Sending the instruction set 00000010 = 02h -> To return the cursor to the home position nop nop nop clr EN ; ;call LCD_WAIT call timer0 setb EN clr RS clr RW mov DATA_BUS,#6h ; Sets the entry mode i.e the cursor always increments nop nop nop clr EN ; ;call LCD_WAIT call timer0 setb EN clr RS clr RW mov DATA_BUS,#14h ; Sets the shift mode to 0 i.e cursor move ,R/L to right shift . nop nop nop clr EN ; ;call LCD_WAIT call timer0 setb EN clr RS clr RW mov DATA_BUS,#80h ; sets the DDRAM address to 00H nop nop nop clr EN ; ;call LCD_WAIT call timer0 ;************************************************************************************** ; Initialization Over ;************************************************************************************** call LCD_CLEAR call LCD_WRITE jmp $ LCD_WAIT: call timer0 Ret setb EN ; clr RS ; setb RW ; mov DATA_BUS,0FFh; nop nop nop clr EN ; JB DB7,LCD_WAIT clr EN; clr RW; ret LCD_CLEAR: setb EN clr RS clr RW mov DATA_BUS,#1 nop nop nop clr EN call LCD_WAIT ret LCD_WRITE: setb EN setb RS clr RW mov A,#'B' mov DATA_BUS,A nop nop nop clr EN call LCD_WAIT setb EN setb RS clr RW mov A,#'O' mov DATA_BUS,A nop nop nop clr EN call LCD_WAIT setb EN setb RS clr RW mov A,#'U' mov DATA_BUS,A nop nop nop clr EN call LCD_WAIT ret timer0: mov R2,#50 timer1: mov R3,#100 ; thats a delay of more than 5 mSeconds djnz R3,$ dec R2 cjne R2,#0,timer1 ret end dejan can you help !! with regards som
"software is also ok (as per me) then why is my lcd not functioning" How did you establish that it is, "ok (as per me)?" Take a look at this Thread: http://www.keil.com/forum/docs/thread1718.asp It tells you how to simulate an LCD - that should at least help you to establish whether or not your software is OK.
