I have an interrupt service routine written in assembly that I am using register set 1 to pass data back and forth to the main program. In my main program I have: BYTE AudioTemp0 _at_ 0x08; // R0 BYTE AudioTemp1 _at_ 0x09; // R1 BYTE AudioRXLo _at_ 0x0a; // R2 BYTE AudioRXHi _at_ 0x0b; // R3 BYTE AudioTXLo _at_ 0x0c; // R4 BYTE AudioTXHi _at_ 0x0d; // R5 BYTE ClockLow _at_ 0x0e; // R6 BYTE Clock10ms _at_ 0x0f; // R7 And in the interrupt service routine I have: Timer2IntSegment SEGMENT CODE RSEG Timer2IntSegment USING 1 I just use the variables directly as R0-R7 for speed reasons. But when I compile I get: *** WARNING L4: DATA SPACE MEMORY OVERLAP FROM: 0008H TO: 0008H *** WARNING L4: DATA SPACE MEMORY OVERLAP FROM: 0009H TO: 000FH *** WARNING L4: DATA SPACE MEMORY OVERLAP FROM: 000AH TO: 000FH *** WARNING L4: DATA SPACE MEMORY OVERLAP FROM: 000BH TO: 000FH *** WARNING L4: DATA SPACE MEMORY OVERLAP FROM: 000CH TO: 000FH *** WARNING L4: DATA SPACE MEMORY OVERLAP FROM: 000DH TO: 000FH *** WARNING L4: DATA SPACE MEMORY OVERLAP FROM: 000EH TO: 000FH How can I tell the linker that this is OK? Do I somehow use an Extern to tell the assembly code that this is OK?
RSEG Timer2IntSegment USING 1 ; - this derective does not switch register bank! It reserve memory for registers. BYTE AudioTemp0 _at_ 0x08; // R0 - reserve the same memory... just remove line "USING 1" from program PUSH PSW MOV PSW,#08H ........... POP PSW - something about this can be used to swicth register bank.
