L4: Data Space Memory Overlap with register set 1 interrupt routine
I have an interrupt service routine written in assembly that I am using register set 1 to pass data back and forth to the main program.
In my main program I have:
BYTE AudioTemp0 _at_ 0x08; // R0
BYTE AudioTemp1 _at_ 0x09; // R1
BYTE AudioRXLo _at_ 0x0a; // R2
BYTE AudioRXHi _at_ 0x0b; // R3
BYTE AudioTXLo _at_ 0x0c; // R4
BYTE AudioTXHi _at_ 0x0d; // R5
BYTE ClockLow _at_ 0x0e; // R6
BYTE Clock10ms _at_ 0x0f; // R7
And in the interrupt service routine I have:
Timer2IntSegment SEGMENT CODE
RSEG Timer2IntSegment
USING 1
I just use the variables directly as R0-R7 for speed reasons.
But when I compile I get:
*** WARNING L4: DATA SPACE MEMORY OVERLAP
TO: 0008H
TO: 000FH
TO: 000FH
TO: 000FH
TO: 000FH
TO: 000FH
TO: 000FH
How can I tell the linker that this is OK?
Do I somehow use an Extern to tell the assembly code that this is OK?
