Anyone familiar with the C51 compiler error as follows: --- error: absrel out of range (l308, $=0X25 Targ=0X485) --- error: absrel out of range (l355, $=0XC Targ=0XA0) --- error: absrel out of range (l443, $=0X1C Targ=0XB1) --- error: absrel out of range (l467, $=0X1F Targ=0XD7) --- error: absrel out of range (l482, $=0X1C Targ=0XA6) C51 COMPILATION COMPLETE. 0 WARNING(S), 0 ERROR(S) Strictly speaking, it doesn't stop the compilation but I wanted to know what the message means and if it will compile the code correctly. I couldn't find any reference to this searching the Keil website. -- Regards, Prasanth Kumar
What version of the compiler are you using? Jon
That was compiled with C51 v6.21. I reran it again with C51 v7.01 and get the following: *** ERROR C253 IN LINE 6471 OF MAIN.C: INTERNAL ERROR (BRANCH TARGET OUT OF RANGE) *** ERROR C253 IN LINE 6471 OF MAIN.C: INTERNAL ERROR (BRANCH TARGET OUT OF RANGE) *** ERROR C253 IN LINE 6471 OF MAIN.C: INTERNAL ERROR (BRANCH TARGET OUT OF RANGE) *** ERROR C253 IN LINE 6471 OF MAIN.C: INTERNAL ERROR (BRANCH TARGET OUT OF RANGE) *** ERROR C253 IN LINE 6471 OF MAIN.C: INTERNAL ERROR (BRANCH TARGET OUT OF RANGE) C51 COMPILATION COMPLETE. 0 WARNING(S), 5 ERROR(S) -- Regards, Prasanth Kumar
You should contact technical support so they can get started helping you with that problem. Jon
