Understanding Output Listings
I am working on a project with an 8k code space limit (Only using the internal flash of the analog devices ADuC824).
I have had some success decreasing the code size by eliminating library routines such as memmove(). And I was wondering if there is any documenation that specifies what the library routine are in the output listing file (*.m51).
Below is the list of library rountines currently used in my project. Some are obvious like (?C?COPY) and (?C?MEMCMP). If I know what the others are I may be able to restructure my code to eliminate them and save some space.
I currently have about 300 bytes of code space left and I still have some functionality to add!
Thank you.
C:\KEIL\C51\LIB\C51S.LIB (?C_STARTUP)
C:\KEIL\C51\LIB\C51S.LIB (?C?COPY)
C:\KEIL\C51\LIB\C51S.LIB (?C?CLDPTR)
C:\KEIL\C51\LIB\C51S.LIB (?C?CLDOPTR)
C:\KEIL\C51\LIB\C51S.LIB (?C?CSTPTR)
C:\KEIL\C51\LIB\C51S.LIB (?C?CSTOPTR)
C:\KEIL\C51\LIB\C51S.LIB (?C?LMUL)
C:\KEIL\C51\LIB\C51S.LIB (?C?ULDIV)
C:\KEIL\C51\LIB\C51S.LIB (?C?SLDIV)
C:\KEIL\C51\LIB\C51S.LIB (?C?LNEG)
C:\KEIL\C51\LIB\C51S.LIB (?C?SLCMP)
C:\KEIL\C51\LIB\C51S.LIB (?C?ULCMP)
C:\KEIL\C51\LIB\C51S.LIB (?C?ULSHR)
C:\KEIL\C51\LIB\C51S.LIB (?C?LLDPTR)
C:\KEIL\C51\LIB\C51S.LIB (?C?LLDCODE0)
C:\KEIL\C51\LIB\C51S.LIB (?C?LSTIDATA)
C:\KEIL\C51\LIB\C51S.LIB (?C?LSTKIDATA)
C:\KEIL\C51\LIB\C51S.LIB (?C?MEMCMP)
C:\KEIL\C51\LIB\C51S.LIB (?C_INIT)
C:\KEIL\C51\LIB\C51S.LIB (?C?LLDIDATA)
C:\KEIL\C51\LIB\C51S.LIB (?C?LLDXDATA)
C:\KEIL\C51\LIB\C51S.LIB (?C?LLDPDATA)
C:\KEIL\C51\LIB\C51S.LIB (?C?LLDCODE)
