uVision4 Beta bug: unable to download application
The following problem renders the uV4 Bete IDE unusable for downloading and debugging an application with my setup.
Note that I have installed the uV4 Beta under the same folder where the toolchain is installed, as recommended.
I would be grateful for any information regarding this bug, especially any about workarounds.
Thanks.
Steps to reproduce:
1. Open a working project (formerly configured for debugging and flash download with ULINK under uV3).
2. Build the project.
3. Connect the ULINK to the computer and the target.
4. Press the LOAD button on the toolbar in order to download the application to FLASH memory.
Result:
1. An error dialog with the followong message pops up:
"Error: Flash Download failed - This old version of 'S166.DLL' is incompatible with uVision (UV3.EXE).
Please use a consistent installation!"
2. After acknowledging the message by clicking 'OK', the dialog is closed, and the application cannot be downloaded ito FLASH.
Current setup:
System: Windows XP Professional, SP2
ULINK: S/N U1948C7E
IDE-Version:
µVision V4.00 Beta 1
Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2009
License Information:
(hidden)
Tool Version Numbers:
Toolchain: PK166 Prof. Developers Kit Version: 6.04
Toolchain Path: D:\Keil\C166\BIN\
EC++ Compiler: EC166.Exe V1.09a
C Compiler: C166.Exe V6.04
Assembler: A166.Exe V5.20
Linker/Locator: L166.Exe V5.21
Librarian: LIB166.Exe V4.26
Hex Converter: OH166.Exe V4.7a
CPU DLL: S166.DLL V2.50
Dialog DLL: D167.DLL V2.45b
Target DLL: BIN\UL2OCDS.DLL V1.08
Dialog DLL: T167.DLL V2.46
