I am using inline assembly in C but i am getting a warning as "UNRESOLVED EXTERNAL SYMBOL".The code is executing but i am getting only the warning. I set all these options: Generate assembler SRC file Assemble SRC file Include in Target Build I have attached my code below
main() { #pragma asm mov a,#24 mov r1,#23 add a,r1 here: ajmp here #pragma endasm }
Search the knowledgebase - this is well documented!
The trouble is, you are converting your 'C' file to assembler - so the Linker only sees an assembler project, and doesn't automatically include the necessary 'C' runtime support!
The trouble is, you are converting your 'C' file to assembler I bungled my way through that one in a mixed (C and assembly) projct. What I found was that you can mix and match as much as you want, as long as main() is C. Since the mixed project was intended for an assembler 'main' I overcame by writing this
main.c:
void main(void) { assemblerMain(); }
worlkoop.a51:
assemblerMain: ... ... ljmp assemblerMain
Note: assemblerMain called many C functions as well
