__forceinline causing Error L6218E?
Using Keil MCBSTM32 (STM32F103RB processor) and uVision3 V3.55a
The goal is to "encapsulate" data in C. To do this I want to create access methods (get/put) that are accessible externally, but the data, being declared static, is not.
I also want to appease those who want faster code so I was attempting to "inline" the methods.
The test code is as follows:
#include counter.h
static unsigned int counter;
 Method to get counter.
__forceinline unsigned int get_counter()
        return counter;
 Method to set counter.
__forceinline void put_counter( unsigned int val)
        counter = val;
The counter.h contains the following:
__forceinline unsigned int get_counter(void);
__forceinline void put_counter( unsigned int val);
(Note: tried the declarations in the .h file with and without the __forceinline)
The main() contains:
static unsigned int opt_test;
  MAIN function
int main (void) {
  stm32_Init ();                                  // STM32 setup
  GPIOB->ODR |=  (1 << (ledPos+8));               // switch on initial LED position
  while (1) {                                     // Loop forever
        opt_test = get_counter();
        opt_test++;
        put_counter( opt_test );
  } // end while
(Note: this was just tacked onto the "Timer" project to try things out)
What I get:
Build target 'MCBSTM32'
assembling STM32F10x.s...
creating preprocessor file for STM32_Init.c...
compiling STM32_Init.c...
creating preprocessor file for Timer.c...
compiling Timer.c...
creating preprocessor file for optimize.c...
compiling optimize.c...
linking...
.\Obj\Timer.axf: Error: L6218E: Undefined symbol get_counter (referred from timer.o).
.\Obj\Timer.axf: Error: L6218E: Undefined symbol put_counter (referred from timer.o).
Target not created
What I have tried: Compiled with optimization levels of 2 and 3.
Is this functionality actually working? If so, is there anything I should be looking out for that might cause this error?
