I am working on a product that links with a third party library that contains functionality that seems to be partially broken. I have narrowed down the source of the problem to a single object file, so I would like to load all the library into memory upon startup _except_ the object file that contains the classes that are responsible for the problem, in a way that I can offer my own implementation of the problematic classes instead. I cannot rebuild the library, alas. Is there a way to so this?
...the armar tool might be helpful in this situation - refer to: infocenter.arm.com/.../index.jsp
Cheers, Ralf
R.Kopsch Senior Applications Engineer ARM Germany GmbH
btw - a summary of "ARM Compilation Tools" is offered at: http://www.keil.com/arm/realview.asp
Thank you.
...I now have put your request into a Knowledgebase-Article, offering some more information - please refer to: http://www.keil.com/support/docs/3733.htm
