Dear All
i have a problem with modified version of USB hostlite with Mr Chans FS SFAT32.
DRESULT disk_ioctl(BYTE drv, /* Physical drive number (0..) */ BYTE ctrl, /* Control code */ void *buff /* Buffer to send/receive control data */ ) { DRESULT res; int result; (void) result; //The FatFs module uses only device independent commands described below. Any device dependent function is not used. //Command Description //CTRL_SYNC Make sure that the disk drive has finished pending write process. When the disk I/O module has a write back cache, flush the dirty sector immediately. This command is not required in read-only configuration. //GET_SECTOR_SIZE Returns sector size of the drive into the WORD variable pointed by Buffer. This command is not required in single sector size configuration, _MAX_SS is 512. //GET_SECTOR_COUNT Returns total sectors on the drive into the DWORD variable pointed by Buffer. This command is used by only f_mkfs function to determine the volume size to be created. //GET_BLOCK_SIZE Returns erase block size of the flash memory in unit of sector into the DWORD variable pointed by Buffer. This command is used by only f_mkfs function and it attempts to align data area to the erase block boundary. The allowable value is 1 to 32768 in power of 2. Return 1 if the erase block size is unknown or disk devices. if ( drv != 0) return RES_PARERR; if (usb_status & STA_NOINIT) return RES_NOTRDY; res = RES_OK; switch(ctrl) { case CTRL_SYNC: // TODO break; case GET_SECTOR_SIZE: *(WORD*)buff = blkSize; break; case GET_SECTOR_COUNT: *(DWORD*)buff = numBlks; break; case GET_BLOCK_SIZE: *(DWORD*)buff = 1; break; default: res = RES_PARERR; break; } return res; }
This function CTRL_SYNC case is flushing the last f_write call, since it is empty.
Someboby could help me?
V.Nagarajan
"Mr" ?
