Our company has developed a PCB containing two ARM controllers. My question is: is it possible to flash both controllers through one single JTAG connector or even better flashing both controllers through one single connector in one go?
Thanks,
Henk
In Keil you should be able to select the device in the chain you want to program.
For more industrial programming, look at Segger's offerings.
If you want to be able to field update the product, consider how the parts talk to each other, and how you can download updates to one or the other.
