Quite often I'll code some of my modules entirely in A51 assembly and, to be thorough, I always fill out the $REGUSE statement for all functions. A module written like this will then provide the necessary information to the compiler for global register optomization.
I've never used inline assembly that much, but recently I did a test where I coded one function with inline assembly. Upon inspection of the resulting SRC file, I can find no $REGUSE statements, and it appears all references to any other C functions in the module have been removed from the .OCR file.
Does this mean that including any inline assembly in a C module excludes all functions in the module from global register optomization ?
Correction: I meant to say the "ORC" file in the 2nd paragraph.
with inline assembly the whole file is, at some point in the process, converted to assembler (you have no C source for debugging such a file). If that conversion takes plece before register optimization, the above would be true.
AVOID INLINE ASSEMBLY IN C51 just make a .a51 module and call it
Yeah, that's kinda the conclusion I've drawn. I've done plenty of .A51 files, so it's no problem other than the time involved. Understand, if I do one function from the module in A51 I prefer to do all function in the module. It's a generic timer resource so I should probably just go ahead and A51 the whole thing.
