My sourcecode files start with numbers like F12_xxx, F13_yyy, e.t.c. So F12 is a higher hierarchical file than F13. I open my files in the IDE (uVision4) starting with the lowest filenumber on the left adding next sequential filenumbers to the right. When opening or closing files (depending on the windows size of the IDE) the sequence is husseld. Is there a way to fix the sourcecode file show-sequence in the IDE?
thanks
Henk
Do you mean the sequence that the files appear in the Project window, or the sequence of tabs for files currently open in editor windows?
i mean:
Not possible, AFAIK.
As Tamir said.
In fact, I don't think that any of the editors I use gives that control - they all just use the order in which you opened them...
