In a project, I'm using the --feedback=unused.txt control in order to remove functions from the final image that are not in use. This works fine except for those functions that are in a library which I have also included. The linker identifies all the unused functions, but is not able to remove them. Unfortunately I have very little flash memory space which makes this feature quite important for me.
I'm using MDK-ARM V3.70
Thanks for your help, Florian
Linker feedback requires a second compiler pass. Object-only libraries cannot be changed.
If you have access to the library source code, you could recompile it with --feedback or --split_sections. The latter, however, could cause other optimization issues.
Regards Marcus http://www.doulos.com/arm/
