RTX and watchdog monitoring
I wondering what method you're using to monitor the sanity state of the RTOS and activate a watchdog in case of failure.
Currently, I have a hardware watchdog feed in the lower priority task . But in some case it's not working :
The RTX can be OK but one task can be stuck , or buffers cannot be allocated or others reasons.
According to you , what is the best method ?
thanks in advance.
  • what you can do it kick your watchdog only if each and every task has set a dedicated bit to 1. if not, the system resets:
    #define SERVICE_WATCHDOG                                lock_mutex(APPLICATION_WATCHDOG_FLAG_DATA) ;\
        g_application_alive_signals |= 1<<(os_tsk_self() - g_first_task_id) ;\
        unlock_mutex(APPLICATION_WATCHDOG_FLAG_DATA) ;
    and
    __task void user_task(void)
        for (;;)
            SERVICE_WATCHDOG
    and
        for (;;)
            SERVICE_WATCHDOG
