Is this a bug for KEIL C?
Create a simple project, use 8051 chip;
input a simple program
void main(void) //1
{ //2 char a,b; //3 a=-1; //4 b=a/2; //5 while(1); //6
build and debug step by step
Open watch window,notice local variable
when it executed at the 6th line.
varvariable b should be 0.
but you will see arvariable b is -1 in the watch window
  • No, it's not a bug at all.
    If you get out your copy of K&R and look at the chapter about arithmetic operators, it say that the direction of truncation for the division operator is machine-dependent for negative operands.
    This means that the result of (-1 / 2) can be 0 or -1 depending on the hardware and/or the compiler. Neither of the results would be considered an error of the compiler.
    If you need a certain direction when truncating the result of dividing a negative number, you will have to do so by hand.
