Hello, I am working on a STR9 scheduler (it is open source - will post a link here when it is ready on the condition you help me to solve this problem :-) ) I don't understand why my code to measure the CPU utilization does not work. It is very simply really: I have an idle task that counts as fast as possible (with the scheduler disabled) upon startup for one second. It saves the accumulated value, then the scheduler is re-enabled and the count begins again, evaluated every second. The ratio between the initial accumulated value and the once per second generated count is the CPU utilization - but the amazing thing is that the one per second count, with the scheduler enabled, tends to the bigger than the initial count (with the scheduler disabled) ! I am quite sure there is no overflow involved - it goes wrong even if I make a measurement every 300 milliseconds (as demonstrated below). Any ideas/recommendations?
// idle task. always executed, and scheduled first static void idle_task(void) { int32u l_scheduler_state ; int32u l_counter = 0 ; scheduler_disable(&l_scheduler_state) ; while (1) { ++l_counter ; // it is faster to count into a register-allocated variable // and later assigned the accumulated value into a static if (timer_poll(IDLE_TASK_TIMER, MILLISECONDS_X_10(30), 0) ) { s_performance_counter_init = l_counter ; l_counter = 0 ; break ; } } scheduler_restore(l_scheduler_state) ; while (1) { ++l_counter ; if (timer_poll(IDLE_TASK_TIMER, MILLISECONDS_X_10(30), 0) ) { s_cpu_utilization = 100 - ( (l_counter * 100) / s_performance_counter_init) ; l_counter = 0 ; debug_message("cpu load %d%\n", s_cpu_utilization) ; } } }
