Keyboard shortcuts storage location?
Does anyone know where the new definitions for new or modified keyboard shortcuts are stored? I looked at 4 .ini files that were modified with the time code of when I made the changes in the UV3 folder and also check the /bin folder......but nothing inside reflects my changes which I'd recognize. I also searched for all .ini files in Keil folder and only found 4 .ini that were time changed/modified.....global/default files/c51/a41 and also a macro file??? > UV3.mac but is a binary.
I just want to be able to drop the file into a new installation without having to manually restore them.
I also looked in the registry under the user block and the system block software keys and they are not there either.
Anyone have an idea?
C
