Can someone explain the F4 and Shift+F4 shortcuts in µVision?
Hello community,
can someone explain the F4 and Shift+F4 shortcuts in uVision?
If you use the "Tip of the Day" function (aka "Did you know..."), you can see some Tips while starting uVision. I am using version 3.33.
One of the tip says: "You can press F4 and Shift+F4 to move to the next and previous build error or Find-in-Files match."
These tips (both for build error and for Find-in-Files match) sounds very interesting for me. But I am not able to manage this.
How does that function?
Martin
