I am having problem to start the PWM.
I have downloaded: http://www.keil.com/download/docs/203.asp
and run it at the simulator. The PWM signal ONLY starts if I tick the TCOU2 at the CCU window!
If I also load TH2 and TL2 when loading TOR2: It seems that the TH2 TL2 is running but only until it reaches 0x0000 and then stops! I do not know why since it was supposed to auto reload with TOR2.
Anyone has come to this? Any idea of how to get this work?
thks
free from http://www.esacademy.com
Thanks Erik
Same problem.
However I have just tested at the the board and it is working .. nice:)
I believe it is something with the Simulator version! CPU DLL: V2.44 Dialog DLL: V2.42c
when they are the best are flawless in simulating the "plain vanilla derivative" functions.
Now visualize the effort it would be to make a simulator that correctly simulated any of the 4711 deviations from "plain vanilla" there are. You wouild not be able to afford it.
do not believe the simulator will correctly simulate functions unique to your particular derivative family
PS acqura has a nice and cheap ICE for the LPC9x family, you may want to look at it.
