Hi to all,
I brought MCB-2300 board (with LPC2378 u-c). And tried the example codes (like blinky) with eval versions of Keil-IDE v3.05 tool chains.
It works well on board when i compile it and load to the board by ISP. But when I try to debug it by simulator it goes in to infite loop, itself in the startp-up code.
(Seems it is hang up in "main osc stabilize" loop in startup code, when i disabled it. It then hangup in "PLL stabilization loop"). I know that was not the solution, but i tried that also.
I am using the startup-file that is provided lpc2300.s as it is in demo code.
Any SW update/patch is avilable for simulator/ startup file/etc? for this problem?
Can any help me, is it some paramater mis-match, bug of startup file, or something else i need to do?
You should try the latest MDK first.
