Hello to all,
i have a problem with my ULINK2 - it started to work really slow. Before when i pressed F11 in debugging the response was immediately but now it takes much longer to do one step in code. I tried really simple code like flashing some LED's and the same problem - really slow steps. Any idea?
Thank you
Check the Max JTAG Clock
I can't set JTAG clock higher than 2MHz because then i get jtag error.
What device are you using? Did you try RTCK as JTAG clock?
I've found out that slow response of ULINK2 is only when I use my other PC (laptop). So this may be a USB issue. I will try to uninstall and then reinstall the ULINK2.
thank you
