Think you. I modified my source :
printf("%lu * %bu = ", N, M); printf("%lu\n", Freq); Freq=25690112L; printf("%lu * %bu = ", Freq, 4); Freq*=4; printf("%lu\n", Freq);
It work correctly. but the Long Integer Multiple fault also.
Run Result: 24500000 * 4 = 4294926936 25690112 * 4 = 1568
i give you answer in other thread!!!
what you expect???
24500000 * 4 = 98000000
NO
biggest unsigned long integer is 4294967296 biggest signed integer is 2147483647
on keil the long integer is 32 bits
you have a maths overflow!!!
in c an integer maths overflow can give undefinededed result
it normally wraps but not is guaranteeed
referr to ansi c book
float maths give error value you think
"A SIMULATOR simulates and as such will NEVER give you the full (and correct) story"
i not think you be right with NEVER!!!!!!
a dedacated simulator for a specifec cpu is posssible to give correct story
but point by me is that compiler probly do not have the bug whot he say before!!!
a small correction:
A SIMULATOR simulates and as such a simulator you can afford will NEVER ......
re "a dedacated simulator for a specifec cpu" dream on.
again: why not just spend 5 minutes and try it with your devboard and emulator instead if spending days discussing it
sir eric
again i sit in corner with hat on and think hard
i do think we basicerally agree on point
do you?????
WHY?
STOP THINKING!!!! stick the stuff on a devboard, hook up the emulator and see the result. WHY ON EARTH 'think' about somethog you can (dis)prove in 5 minutes??????
"The C8051F120/1/2/3 devices include a multiply and accumulate engine which can be used to speed up many mathematical operations."
OK - the MAC engine can be used that way - but do the Keil tools support it?
Does the option that you are selecting relate specifically to the MAC engine on the SiLabs C8051F120/1/2/3 devices?
"My Program runs on simulator"
And so it should! The Simulator will simulate the on-chip arithmetic acccelerator that the tools expect - if your real hardware doesn't have such a feature, then it obviously won't work properly on that hardware!
Thanks all.
to sir Eric it run correct on hardwaaare? My hardware circuit board is producing, and my board will connect several systems which are developping too.
The communication protocol between systems is constitute. So We can program and debug synchronously. I developped the MCU program and a AGSI DLL for Simulator other systems.
Even if run on the hardware, we cannot acquire other systems for debuging our hardware.
So simulator is very important method for us.
C8051F120 has 120KB Flash Code memory. My Mcu program size is 80KB now. and It would grown to 100KB or more. so emulator is download code to board slowly , and the mcu can be programed for limitted times, Then if debug it on hardware, we need offen repace the MCU. I closed the On-Chip Arithmetic Accelerator when simulating, I'll try on-chip accelerator on board,when finished simulation.
to sir Andy OK - the MAC engine can be used that way - but do the Keil tools support it? Keil support the MAC of C8051F, On "Target Options", if you select other MCU such as "Intel 8051H", the "On-chip Arichmetic Accelerator" option will dispear.
"STOP THINKING!!!! "
sir erac
that is VERY bad idea you say me!!!
persoon must think to design project!!!!
it called planning you know
i give you book on design for you be learning ????
OK, so we've established that your chip does have an arithmetic accelerator, and the Keil tools do support it...
"My Mcu program size is 80KB now."
So you must have a full, licensed copy of the tools, then?
In that case, you should contact Keil support with this issue.
Have you also contacted Silicon Labs?
So you must be using some kind of banking?
Have you checked carefully if there are any particular issues in using the accelerator with banking?
mr erac
here is good book i read for you please
books.google.com/books
Taken out of context;
since you seem to have a problem understanding contexts, I shall "bend it in neon" for you.
when a 5 minute experiment can give the answer, STOP THINKING, make the experiment and go on with the gained knowledge
books.google.com/books based on the description you give of what you do, you are waaaaaaaaaaay too far out doing something like this while reading beginners guides. Start with something suitable for beginners.
PS WHO IS "Sir Erac" ?
One problem with the concept:
Thinking can result in the correct answer.
On the other hand, testing can result in a false positive/negative, because without thinking, not all parameters may have been correctly tested.
It is often better to know why something works/doesn't work, then to deduce the function by trial and error.
boook i now read is this
books.google.com/books://www.google.com/search%3Fhl%3Den%26safe%3Doff%26rls%3Dcom.microsoft%253Aen-US%26q%3D%2522software%2Bengineering%2522%2Bbook&sa=X&oi=print&ct=result&cd=3
it do good teaching of enginnering
it teached me that thinkng is good
i now prograam for money on computer and soon be big rich!!!!!!
you need me when i give you help? for friend i not charge you big!!!!
I would typically agree with you; however, in this particular case. the questions is "does the simulator simulate correctly".
'Thinking' will not help here, however a 5 minute effort trying the same on the emulator will give the absolute answer. If the answer is the same, the code (or the compiler) is faulty, if the answer is different, the simulator is faulty there is no possibility of a "false positive/negative"
"better to know why something works/doesn't work". I doubt anyone but a Keil employee would have any benefit from finding out why the simulaotor does not work, should that be the case.
No, there is absolutely nothing wrong with 'thinking' when applied where efficient but spending days 'thinking' about something when an experiment can give the total and absolute answer is definitely not applying 'thinking where efficient'. This is especially ludicrous when the answer, beyond yes or no has no value to the 'investigator'.
The OP stated in an earlier post that the simulator worked when "hardware acceleration" or some such thing was not specified which directly would be revealed as either code, compiler or simulator error by the simple test I suggested.
Now, if the OP insist on 'thinking' there even is a simple means of analyzing by that method: check the generated assembler. That, of course, again, is much more cumbersome that a 5 minute test.
PS just to repeat; I strongly advise against determining things by 'experimenting' unless, as in this case, the answer is absolute and paametre variance independent. Especially when tool performance is in question an experiment (or looking at the generated assembler) is often the only way to determine the facts.
