Hi Friends,
I have been working on CY7C68013A EZ-FX2LP USB based micro controller, I have written code for IN/OUT operation i.e, Read and Write operation of USB.
I am initially reading data from HOST a bulk 64 Bytes of data and storing it in a location starting from 0xE000 which is the starting address of scrachpad memory of 512 Bytes, after which if i want to read data from this location I am initially getting a JUNK first time ,latter next read I get actual value, I mean to say that after write is done to this memory location in RAM, every first time i read I get previous value and the actual value is only reflected in the next read operation,
I tried a lot , but i am not able to find out what is the exact problem, I have pasted code below.
// INITIALIZATION CODE void TD_Init(void) // Called once at startup { BYTE i=0; // we are just using the default values, yes this is not necessary... EP1OUTCFG = 0xA0; SYNCDELAY; EP1INCFG = 0xA0; SYNCDELAY; // see TRM section 15.14 EP1INCS = 0x00; SYNCDELAY; EP2CFG = 0x82; SYNCDELAY; EP2BCL = 0xC0; // arm EP2OUT by writing byte count w/skip. SYNCDELAY; EP2BCL = 0xC0; // arm EP2OUT by writing byte count w/skip. SYNCDELAY; EP1INBC = 0x40; // EP2BCH = 0x02; // arm EP2OUT by writing byte count w/skip. // SYNCDELAY; // EP2BCH = 0x02; // arm EP2OUT by writing byte count w/skip. // SYNCDELAY; // enable dual autopointer feature SYNCDELAY; AUTOPTRSETUP |= 0x01; } TD_Poll() { /* -> USB OUT PACKET TRANSFER MODULE -> BULK - 64BYTES -> EP2 - ENDPOINT 2 -OUT DATA TRANSFER */ if(!(EP2468STAT & 0x01)) { ACC =XBYTE[0x8800]; Addr = 0xE000; // scrachpad area starting Addr AddrFIFO = 0xF000; //EP2FIFO starting Addr for( i = 0x0000; i < 64; i++ ) { XBYTE[Addr++]= XBYTE[AddrFIFO++]; } SYNCDELAY; EP2BCL = 0xC0; ACC=XBYTE[0x8800]; } /* -> USB IN PACKET TRANSFER MODULE -> BULK - 64BYTES -> EP1 - ENDPOINT 1 -IN DATA TRANSFER */ if(!(EP1INCS & bmEPBUSY)) //check for EP1IN bit, wait for BUSY Bit =0 { count=EP1INBC; // Load count with EP1 received buffer size /* for(Addr=0xE000;Addr<0xE040;Addr++) // load data to scrachpad RAM ,starting from 0xE000 to 0xE040 (64Bytes) { XBYTE[Addr]=in; // Incremental data for every read operation from HOST } in++; */ // Increment value for one Read operation Addr=0xE000 ; // Intial ScrachPad Address for(i=0;i<count;i++) // 64 Bytes Loop Count { // EP1INBUF[j]=BufferOUT[i]; // Transfer Data from scrachpad RAM Area to EP1 EP1INBUF[j]=XBYTE[Addr++]; j++; } SYNCDELAY; // Sychronization Delay j=0; EP1INBC = 0x40; // Re-Arm EP1 Byte Count SYNCDELAY; // Sychronization Delay ACC=XBYTE[0x9800]; // LED 3 ON SYNCDELAY; ACC=XBYTE[0xA800]; // LED 4 ON SYNCDELAY; } ACC=XBYTE[0x8000]; SYNCDELAY; ACC=XBYTE[0x9000]; // LED 3 ON SYNCDELAY; ACC=XBYTE[0xA000]; // LED 4 ON SYNCDELAY; } }
Please reply me if there is any mistake, waiting for a positive reply,
Abhilash
Did the code look readable in the preview?
Dear Per Westermark,
Yes, the code was Readable in preview, every time i read first 64 Bytes of data is the previous written data and next actual data,
Please find a solution for this,
"Yes, the code was Readable in preview"
Really?!
Do you really think that the source code as shown is legible?!
ie, do you really think that it is clearly laid-out and easy to read?!
It looks like you've used TABs to lay-out your code? You need to convert the TABs to spaces - TABs just cannot be relied upon to format the same way on different applications!
In fact, TABs can't even be relied upon to consistently format the same way in the same application!! (because the user can fiddle with the TAB settings).
Any decent editor (even uVision) can be set to insert spaces instead of TABs.
