Hello!
I've installed Uspear driver flash downloading on my ADuC847 (from ">http://www.keil.com/download/docs/285.asp
Compilation finishes with success. But I can't download the program on the board. The following message appears: "Flash download Failed - Target DLL has been cancelled".
Have you got any ideas concerned with it?
I had the same problem with Uspear (USB Version). Keil message: "Flash download Failed - Target DLL has been cancelled"
Solution:
The Spear-Keil-Drivers that you can find on the accutron homepage didn't work with Uspear (USB). But the drivers on my installation CD of Uspear did work.
I confirm with the spaer_keil_drivers the problem was solved.
In the debug tab of target configuration select the "other" Accutron emulator (i.e "Uspear(Accutron) Ltd"
