Using GPIO Port #1 after exception vector remapping to RAM causes CPU crash
Hi To All,
Currently I observe very strange situation when I have started to use remapping of exception vectors to RAM after application gets started from internal flash – the load/programmed area (used CPUs :STR710 and STR11):
Application starts running just fine, but ….
When the following functions are called
GPIO_BitWrite(GPIO1, 9, 1); // setting the bit 9 of IOPORT1
GPIO_BitWrite(GPIO1, 9, 0); // resetting the same: bit 9 of IOPORT1
… Application stacks and I see exception vector area in RAM - changed
Remark :( Prior calling these both functions the pin is set to output with:
GPIO_Config(GPIO1, 0x0200, GPIO_OUT_PP);)
Some more info and details I was able to find so far:
1).The situation does happen if there is a delay between the two calls (called functions without delay one after another does not cause a problem);
2) Both of them have to be called the problem to happen;
3) Not using library functions, but direct access to register instead via pointer, like that:
(U16 *) pGPIO1 = (U16 *)(0xE0000000+ 0x4000+ 0x0c);
... Does not help – same result
4) I have tried two tool chains – RV MDK's and Keil's – same result;
5) I have tried two different ways of expectation vectors remapping:
- The way described in ST forum with RV MDK's tools;
- Using manual way with Keil's tools, with code like this at the beginning of main():
// remap
U32 index;
U8* dst = (U8*)0x20000000; // beginning of RAM, 64 bytes reserved via linker setting
U8* src = (U8*)0x40000000; // beginning of internal FLASH first 64 bytes are reset vectors
U32* pboot = (U32*)0xA0000050; // booting register address
for(index = 0; index < 64; index++) dst[index] = src[index]; // copy vectors to RAM
index = *pboot;
index = index & 0xFFFFFFFC;
index = index | 0x2;
*pboot = index; // set 0x00000000 to RAM
// remap
… and result is the same
Someone has the same situation?
Thanks a lot in advance for any help!!
Nivelinn
