Hello, i have a problem with my first program in the arm core I have a little FW who I load in my test machine via jtag with a ulik and all work correctly but if i want debug my application all is bloked, in particular mode the keil run the debbugger, and after the application not go to main and its is blokked there are necessity of ini file?
I suggest you to start with a working example; in your toolset installation you can find several folders with working samples for almost all the existing evaluation boards; try one of them and try to understand what are the differences between the working example and your application (project settings, startup file, etc...).
