STR9 -NOINIT- Variable on powerup or reset
Does any body know how to make a variable non initialize to zero on RESET or powerup with Battery backup.
I tried declaring memory bank IRAM1 - as NOINIT and scatter file loading (select Other area as IRAM1), but it doesn't work. Scatter file indicate NOINIT for this bank of memory address.
I created a sample program write a text in an array, verified the array in Memory window, then i give reset from menu and break the program on main(). I found that the array is initialized back to zeros.
Please forward your suggestion to resolve the issue.
