Hi
When defining to (or more) registers at the same address the linker return error (memory overlap). How to solve this ?
Ex:
// Read only volatile union { U32 REG; struct { U32 MIS : 1; // RD U32 :31; // RD } BIT; } I2CMMIS __at (0x40020018);
// Write only volatile union { U32 REG; struct { U32 IC : 1; // WR U32 :31; // WR } BIT; } I2CMICR __at (0x40020018);
"want to use different name to the registers when reading or writing"
Isn't that exactly what a union gives you?
Why not:
volatile union { // Read-Only volatile union { U32 REG; struct { U32 MIS : 1; } BIT; } MIS; // Write-Only union { U32 REG; struct { U32 IC : 1; } BIT; } ICR ; } I2CM __at (0x40020018);
No because want to use different name to the registers when reading or writing
Have a union encompassing both definitions?
