Started this morning on something. Then needed to add printf in simulator mode. So I added putchar() and printf. But then I found that the program didn't run. When I hit RST it is always sitting on line #252 SWI_Handler B Undef_Handler in startup.s
To double check I eventually ran the demo hello.c in program files\keil\arm\examples\hello\hello.c - this works fine.
But when I copy hello.c + serial.c to a new folder and start a new project it compiles fine - but does not run, again it stops on line #252 as above. When I check I find that the Realview compiler is selected and the Configure flash tools shows a tab with C/C++. The startup.s file mentions 2006-2006
On the original hello example it is using the CARM compiler and the configure flash tools shows a tab with just a C on it. The startup file mentions 2002-2004
So there are differences. The c files are identical but the startup.s files are not, the old examples work but compiling new versions with the newer startup.s and Realview don't.
Has anyone had similiar problems, can someone explain what is going on please.
Sorry, I should have added. I am using the Philips target only.
In Program files\Keil\Arm\Startup\startup.s is the 2002-2004 headed file. (STARTUP.S: Generic ARM Startup file)
In Program files\Keil\Arm\Startup\Philips\startup.s is the 2002-2005 headed file.(STARTUP.S: Startup file for Philips LPC2000)
In Program files\Keil\Arm\RV30\Startup\Philips\startup.s is the 2005-2006 headed file.(STARTUP.S: Startup file for Philips LPC2000)
It appears that I am somehow using the wrong startup files although by default the 2005-2006 one is the one selected, but not working.
Tell you what,
suggest offloading some of your work to the other person, whatever could be possible i mean, is it healthy to take the whole thing on your head, plz reply,
