Gentlemen(Ladies):
I've been wrestling with trying to get output from one of the two UARTs on my Keil MCBSTR9 board (vers 3). All to no avail. I've checked baudrates and the setup of the UART and the System Control Unit. Part of the attached code works (LCD output, LED output) so I know that at least the processor is coming out of reset and is running some code. Trouble is, when I try to send a character out the port, the code hangs. If I comment out the two calls to sendchar(), the remaining code runs fine.
I've posted my code below (with comments explaining what I was attempting to do. If it is simple enough to identify what I'm doing wrong, I would greatly appreciate being educated.
Or, if deciphering my bad code is beyond the wit/patience of man, then I would appreciate a sample of any serial port code that DOES run on the MCBSTR9 board.
I apologize in advance for the appearance of the code after I copied it from the IDE to the form posting editor. I tried my best to clean it up, but I'm not at all happy with how it renders (at least on my browser). Any suggestions on how to fix that problem would be duly noted and taken on board.
//*************************** TEST.C ************************************ // Auth: R. McCoy // Date: 9/30/2006 // Gist: Blinks LEDS on port 7 of Keil MCBSTR9 board. Also TRYING to spit a // character ('A') out of COM1 (UART0). // Note: It appears that there is an error in the documentation on page 78 of // ST Manual UM0216 (STR91x Reference manual). The SCU_GPOINn register // documentation makes no sense whatsoever. Only 8 bits are shown...not // the 16 bits that should be depicted. Also, why does the table jump from // pin3 to pin7 (going right to left)? // Stat: No luck so far. // // Targ: Using the Keil MCBSTR9 Demo Board: // COM1 is connected to pins P3.0 (Rx) and P3.1 (TX) // COM2 is connected to pins P3.2 (Rx) and P3.3 (TX) // // Per Table 4 of the Str91xF (ARM966E-S) datasheet (STR912FW44.pdf): // UART0 Rx is Alt Input 1 on GPIO_3.0 // UART0 Tx is Alt Output 2 on GPIO_3.1 // // Board is operating at 48 Mhz and the BRDi and BRDf registers // are set up to generate a baudrate of 115,200. //*********************************************************************** #include <91x_lib.h> #include "LCD.h" int sendchar(int ch); int retval; int main (void) { unsigned int i; SCU->GPIOOUT[7] = 0x5555; /* P7.0..7 output - mode 1 */ GPIO7->DDR = 0xFF; /* P7.0..7 Outputs (LED Data) */ /* LCD Setup......................................................*/ GPIO8->DDR = 0xFF; /* P8.0..7 Outputs (LCD Data) */ GPIO9->DDR = 0x07; /* P9.0..2 Outputs (LCD Control) */ /* UART1 Setup.....................................................*/ SCU->GPIOOUT[3] &= 0xFF3F; /* Enable UART0_TX (COM1) connected to P3.1 */ /* by setting bits 6 & 7 to 0 first */ SCU->GPIOOUT[3] |= 0x0080; /* then by setting bit 7 to 1 */ /* this sets GPIOOUT[3] to "Alternate Output 2" */ SCU->GPIOIN[3] |= 0x01; /* Enable UART0_RX (COM1) connected to P3.0 */ /* by setting bit 0 to 1 */ /* this sets GPIOIN[3] to "Alternate Input 1" */ UART0->IBRD = 0x1A; /* Integer divider for 115kBaud */ UART0->FBRD = 0x03; /* Fractional divider */ UART0->LCR = 0x0060; /* 8 bits, no Parity, 1 Stop bit, FIFO disabled */ UART0->CR = 0x0301; /* Enable UART, Receive Enable, Transmit Enable */ lcd_init(); lcd_clear(); lcd_print (" TEST.C "); /* this line of code works */ set_cursor (0, 1); lcd_print (" Sept. 30, 2006 "); /* this line of code works */ /* retval=sendchar('A'); if this line is left un-commented, the code */ /* compiles and loads, but the program hangs */ for (i = 0; i < 5; i++) wait(); /* Wait for initial display */ while (1) { /* Loop forever */ int n=0; for(n=0x01;n<=0xFF;n<<=1) /* scroll thru all eight LEDS */ { GPIO7->DR[0x3FC] = n; /* Turn on LED ...this code works */ wait(); /* Delay */ /* retval=sendchar('A'); if this line is left un-commented, the code */ /* compiles and loads, but the program hangs */ } } } int sendchar (int ch) { /* Debug output to serial port. */ if (ch == '\n') { while (!(UART1->FR & 0x0080)); UART0->DR = '\r'; /* output CR */ } while (!(UART1->FR & 0x0080)); return (UART0->DR = ch); } void wait (void) { /* Wait function */ long d=950000L; /* 950,000 gives a delay of about 1 sec. */ while (d--); /* Only to delay for LED flashes */ }
Thanks in Advance, -=Rich=-
Looks like you are configuring UART0, but sendchar() uses UART1 flag register's TXFE to pace output through UART0 data register. That seems odd to me.
Regarding code rendering, that looks like a tab-size versus tab-with-spaces/tabs thing. Control the amount of indentation with tab-size, but always tab/indent with spaces. That way all tools (make being an exception) render the same. There's no real reason to use 0x09 (ctrl-I) for indentation to save disk space anymore. It's not like were trying to pack every little bit onto a floppy.
If your coding standards require that you use literal TAB characters for indentation, then you need to pass the code through a filter that makes the TAB-to-space(s) translation before publication.
