In one of my project i connected 8031, 27c256 and 8255.Here the A15 line is given common to Chip enable of EPROM and also connected to G1-pin of address decoder via a NAND gate.
So if the A15 is low eprom is selcted and if high 82c55 is selected.
But now i want to use 64kb eprom. I cannot connect the A15 like above.
Can anybody suggest how to do the accessing?
exactly the same way as before because normally the eprom lives in code space and the pio in XDATA space. HINT: the EPROM should be accessed via PSEN the PIO via /RD and /WR.
BTW: all of your devices are obsolete.
Thomas
Now the problem comes in the selection of chip.
Bcos previously i used the A15 to select the EPROM and the 8255 using my program.
Now the A15 is used and i cannot access 8255.
If want i can send the circuit but how attach the pdf file to this forum?
You can't attach files on this forum.
You will have to post it somewhere accessible, and give a link to it
"previously i used the A15 to select the EPROM and the 8255 using my program. Now the A15 is used and i cannot access 8255"
Did you read the Hint from Thomas Zepf?
Do you have anything else mapped into XDATA space?
if possiblecan u give ur mail id so that i can send the circuit and tell me how to solve?
if possiblecan micro give microresistor mail id so that i can send the circuit and tell me how to solve?
I decoded the abbreviations and it still makes no sense
There are electronics stores around, why did you buy components in an antique store?
I am in need of how to access the 8031 with 27C512 (64KB EPROM), 6264(8KB RAM), and 82c55.
The main problem is the chip select.
my mail id is: shankar@triotech.com.sg
The main problem is the chip select. Irrelevant
I am in need of how to access the 8031 with 6264(8KB RAM), and 82c55.
The main problem is the chip select. No, "The main problem is" you using the antique 8255, but if you persist wit5h this stupidity, use A15
The whole purpose of a forum is that everybody learns, e-mail correspondances are worthless for the community as a whole.
