AT91SAM7S system interrupt
I have a small test program where the only interrupt I've enabled is the periodic interval timer, and it's been configured to generate 1-msec interrupts.
The system peripheral interrupt service routine...
1) toggles an I/O pin to show it's been serviced
2) if the PIT interrupt is active, then
2a) reads the PIVR register to clear the interrupt,
2b) toggles a (2nd) different I/O pin
The main loop toggles a (3rd) different I/O pin.
The problems are:
A) Even though the I/O pin associated with the periodic interval timer (PIT) is toggling every 1-msec like it should, the other I/O pin in the system peripheral interrupt service routine that shows when the system peripheral ISR has been serviced toggles virtually continuosly (every 4 or 5 usec's with a 25 MHz MCK).
B) The 3rd I/O pin that's supposed to toggle forever in the main loop never toggles.
I've tried trapping all the system peripheral interrupt sources I can find documented in the datasheet, but none of them (other than the PIT) appear to be active.
Question 1 = Can anyone point me to a place in the AT91SAM7S datasheet that clearly defines what all the system peripheral interrupt sources are? I ask this because of the datasheet text that says things like "the system peripheral interrupts, such as the periodic interval timer, debug UART, etc.". It's the "etc." that's throwing me off. I've been unable to locate any definitive text in the datasheet that says "these are all the possible sources of system peripheral interrupts".
Question 2 = Are there any system peripheral interrupts that are enabled by default, i.e., by the generic SAM7.s code generated by the KEIL tools when a new project is generated?
Question 3 = Can anyone tell me how to clear *all* possible sources of system peripheral interrupts (before globally enabling interrupts), so that I can make sure the only one that's been enabled is the single PIT interrupt that I explicitly enabled?
Thanks,
Dave.
