iam working in 8051 microcontroller i want to know about the dynamic memory allocation in Keil c just operation of memset
memset() has nothing to do with dynamic memory allocation, but if you want to know about memset(), the manual wouldn't be a bad place to start:
http://www.keil.com/support/man/docs/c51/c51_memset.htm
Your favorite C textbook likely mentions memset() too.
Oh well, both original links worked from the preview, but after posting the link gets prefixed with some extra keil.com/forum/docs/ URL stuff and gets quoted.
Just copy the link from your browser and paste it into the browsers URL/Address text box.
iam working in 8051 microcontroller i want to know about the dynamic memory allocation in Keil c All you need to know about "dynamic memory allocation" on the '51 is DO NOT USE IT.
The architectore, and the compiler mechanisms forced upon the compiler design by the architecture, makes dynnamic memory allocations something to be avoided when working with the '51.
There are things that Keil C for '51 can do which never should be used, they should never have been included, but Keil, to comply with ANSI, had to.
Once more "the '51 ain't no PC"
