in the page http://www.keil.com/support/docs/2187.htm it is said, to enable the feature of "logic analyzer", "the target debugger must be able to capture signals". I want to know what the meaning of "capture signals" is. Thanks! Karah
Currenlty only the HITEX ARM EMULATOR PLUG-IN supports this feature when working with ETM.
do you mean the capture signal capability is the feature of embedded test module?
