Hi all, I am writin here for the first time. I am not able to open the serial port debug window of my simulator from my keil uv2 IDE. I am using TI based MSC1210Y2 chip. I have a registered version of uv2 IDE. Whereas when i send some data on my serial port on my code and when i used keil uv3 IDE which is a evaluation version , i am able see the data on the serial window of my simulator . Help will be appreciated in this regards Amit
What is the version number of the registered UV2 version. Are you within support?
Version number mentioned is uv2 V2.05.I have started using this recently so am not so sure where i am in support or not. Am i missing somthings to be set in the project properties which does allow me to see the simulator serial port window. Or is is that the TI based MSC1210Y2 chip does not support simulation.
This version is about 6 years old and pre-dates the release of that TI device. Please contact your local distributor an get an update to the current release.
