Hi Is there a way to setup Ulink only for programming purpose ? I have the linked ELF code but no sourcecodes for a project. Can this be done through some INI file ? How?
http://www.keil.com/support/docs/3061.htm
Look for the "Load" button on the toolbar. That's what it's there for. You may have to create a dummy project for this purpose, so that via the "Project-Options-Output" dialog box you can specify the name of your ELF file. Hope this helps.
